14 years agoDDR2 External Memory Interface
I want to test one DDR2 memory using the example with ALTMEMPHY megafunction on cyclone IV, it compiles without errors or critical warnings, but when I use the ALTMEMPHY External Memory Interface Debug Toolkit it stops at the stage "Read resynchronisation phase calibration", anyone knows how to solve this?, Thank you.1 Reply
I've read from the uniphy doc that calibration failure at the read stage usually involves problem with address/command clock phase and address/command board skew and delay. what numbers did you use for those parameters?
