19 years agoDDR2 Design with Cyclon III
Hi all I just started a new desing using a Cyclon III to interface discrete DDR2 memory (No DDR2 module!). It is just one single chip per interface. Can someone help me choosing the right...
18 years agoHi
I am still developing the board. Now I am just before starting to layout the PCB. I have done a lot of simulating for signal integrity. I simulated for 167MHz Clock speed. All traces impedanz controlled to approx. 50Ohm This is what i found out: - If i keep the lines below 3cm in length I don't need any termination due to reflexions - Need to control drive strength in FPGA to eliminate over/undershoot - Need to run DDR2 in reduced drive strength - clock termination 100Ohm diff. Bottom line is: Except for clock there is no additional termination on board, but we need to reduce drive strength. Alex
