17 years agoDDR2 Controller Preset Files
Hi, I am interested in using the HP DDR2 Controller IP with a 4Gbit DDR2 RAM chip MT47H512M8THM. In SOPC Builder there are no presets for this chip. Does anyone know where I can get these preset fi...
17 years agoI don't have the file but I can suggest a methodology to limit the pain of getting the parameters. If no one has the sheet available then you might do the following, find a similar part (hopefully from the same manufacturer) that is listed in the parts of the megawizard in the High Performance DDR2 controller. Click the customize and in there you can see all the parameters, match those numbers up with the data sheet on that part, now you have an idea of how they correspond name-wise. Now take that knowledge and do the same with your actual part. Again this is best if you can do it with same manufacturer as they will have the same name and similar positions in the datasheet hopefully.
