16 years agoDDR2 and DDR3 SDRAM High-Performance Controller
Dear all; Can I use Debug Toolkit for DDR2 SDRAM High-Performance Controller when DDR2 is controlled by Nios II processor? Can someone tell me how to use it if the answer is possible? I ...
16 years ago --- Quote Start --- If you are debugging to this level I would first remove your nios driver and just use the example_top design provided when generating the IP. --- Quote End --- This is what I'm trying to do, but this error appears when compiling the project: "Error: Node instance "altmemddr_0_inst" instantiates undefined entity "altmemddr_0"" What shall I do ?
