15 years agoDDR PIN placement error
Hi all, I use a Cyclone IV E EP4CE40F23C8 with Quartus 11.0 I have this error message when i try to place ddr pins --- Quote Start --- Error: altmemphy pin placement was...
14 years agoHi Dave,
--- Quote Start --- I am using the Stratix IV devices --- Quote End --- In the more commercial projects we have to do with Cyclone IV and if possible the smaller (cheaper) ones, my customer keeps repeating almost daily ... --- Quote Start --- Write a DDR2 interface independently of the Altera IP? --- Quote End --- I'm doing exactly that, as a midnight project though. And I must confess, playing it safe, I stuck to the 'Altera assigned DQS/DQ/DM pins' while developing my PHY. But as I said we swapped a few pins incorrectly and in this project I was going to use the Altera IP (until I got my PHY and Controller tuned) to get the system off the ground. Now my partner-developer is complaining that he has to run a NIOSII Ethernet stack with just the internal memory ... My Phy and controller are quite small compared to the Altera IP, and are dedicated to driving a single memory chip ( or at maximum a single rank Dimm) only and is targeted at Cyclone devices. (Although the idea should also work for Stratix devices ...) I'll compare a compilation with some non DQS-DQ pins to the compilation with 'correctly assigned' pins. Regards, Josy
