15 years agoDDR PIN placement error
Hi all, I use a Cyclone IV E EP4CE40F23C8 with Quartus 11.0 I have this error message when i try to place ddr pins --- Quote Start --- Error: altmemphy pin placement was...
15 years agoHi Dave,
--- Quote Start --- DDR2/3 interfacing requires phase shifting the strobe clock to capture the data. --- Quote End --- In Cyclone IV the DQS is not used to capture the DDR2 data. This is stated several times in the Cyclone IV data-sheet. Instead ALT-MemPHY uses a phase-shifted clock from the PLL (that generates all memory clocks) to capture the data. It looks to me that all (most) IO-pins are created equal (DDR-out an OE registers etc. in the IO-cell, DDR-in registers in the logic fabric) so how come the DQ/DQS/DQM-pins are more equal? That is the mystery I'd like to see revealed. Regards, Josy
