14 years agoDDR controller pin placement
Hi All, I have two problems with the 16 bit DDR controller generated by Megawizard in my design with EP3C16E144I7. (1) I assign CK to pin 71 and CK# to pin 72. After compilation, I get ...
14 years agoYeah, I think that is something I can expect, because this is just a warning.
What I don't understand is : if I really change CK/CK# to DIFFIO pins, why do I get an error, which is even worse? Does this mean the warning message is quite misleading? BTW, zju2010, do you also have the VHDL data type std_logic_vector(0 downto 0) in your generated DDR controller? Can you make it generate std_logic, instead of std_logic_vector(0 downto 0)?
