mriemleit
5 years agoDDIO Output Timing Errors on a Source Synchronous Interface (RGMII)
Hi Intel Community,
I've got problems with the timing of a RGMII Interface.
In my design the FPGA imitates an Ethernet PHY. So the FPGA has to delay the RX and TX clock by 90 degree internally....
Ash_R_Altera
5 years agoHi,
Can you try with following constraint changes to the sdc?
1) Add create_clock constraint for the clk_in of the pll.
2) Add derive_pll_clocks
3) Remove create_generated_clock constraints as the derive_pll_clocks does the required job.
- mriemleit5 years ago
Hi Ash,
thanks for your time and help!
I added 1) and 2) => I've still the same problem.
3) I'm sorry but, I don't know what you mean.
I've an output clock (RGMII125_TxClk) and the 90° shifted clock that is set on the output pin (RGMII1Data_TxClk). How can I tell the timing analysis to analyse setup and hold time, related to the clock at the output pin when I don't name them?
The "create_generated_clock" statements are from page 10 of: an433.pdf
The names are quite bad, so I updated them in the .sdc file:
# create BaseClock create_clock -name RGMII1_RxClk -period 125MHz [get_ports {pil_rgmii1_rxClk}] # Generate 125 MHz Clock create_generated_clock -name RGMIICLK_Data -source [get_pins {inst_Rgmii1Slave|i_rgmiiPins|inst_rxPll|iopll_0|altera_iopll_i|twentynm_pll|iopll_inst|refclk[0]}] [get_pins {inst_Rgmii1Slave|i_rgmiiPins|inst_rxPll|iopll_0|altera_iopll_i|twentynm_pll|iopll_inst|outclk[1]}] # Apply a generated clock to the clk_out port create_generated_clock -name RGMIICLK_Clk -source [get_pins {inst_Rgmii1Slave|i_rgmiiPins|inst_rxPll|iopll_0|altera_iopll_i|twentynm_pll|iopll_inst|outclk[2]}] [get_ports {pol_rgmii1_txClk}] derive_pll_clocks -create_base_clocks derive_clock_uncertainty set t(maxDelay) 1.0 set t(minDelay) -1.0 # Set output delay based on the requirements mentioned previously set_output_delay -clock RGMIICLK_Clk -max $t(maxDelay) [get_ports pov_rgmii1*] -add_delay set_output_delay -clock RGMIICLK_Clk -min $t(minDelay) [get_ports pov_rgmii1*] -add_delay set_output_delay -clock RGMIICLK_Clk -clock_fall -max $t(maxDelay) [get_ports pov_rgmii1*] -add_delay set_output_delay -clock RGMIICLK_Clk -clock_fall -min $t(minDelay) [get_ports pov_rgmii1*] -add_delay set_output_delay -clock RGMIICLK_Clk -max $t(maxDelay) [get_ports {pol_rgmii1_txCtl}] -add_delay set_output_delay -clock RGMIICLK_Clk -min $t(minDelay) [get_ports {pol_rgmii1_txCtl}] -add_delay set_output_delay -clock RGMIICLK_Clk -clock_fall -max $t(maxDelay) [get_ports {pol_rgmii1_txCtl}] -add_delay set_output_delay -clock RGMIICLK_Clk -clock_fall -min $t(minDelay) [get_ports {pol_rgmii1_txCtl}] -add_delay # Set false paths to remove irrelevant setup and hold analysis set_false_path -fall_from [get_clocks RGMIICLK_Data] -rise_to [get_clocks RGMIICLK_Clk] -setup set_false_path -rise_from [get_clocks RGMIICLK_Data] -fall_to [get_clocks RGMIICLK_Clk] -setup set_false_path -fall_from [get_clocks RGMIICLK_Data] -fall_to [get_clocks RGMIICLK_Clk] -hold set_false_path -rise_from [get_clocks RGMIICLK_Data] -rise_to [get_clocks RGMIICLK_Clk] -hold set_false_path -to [get_ports {pol_rgmii1_txClk}]
