13 years agoDDIO bitclock location and clkctrl blocks
Hi
I'm using a Stratix III EP3SL340 C3 (Terasic DE3) and I had a question about DDIO and where to place the bitclock with respect to data. And if I should route it via clkctrl blocks. I have 12 bit data from an ADC (AFE5807) coming in at 80MSPS. I wanted to use DDIO to receive the data. I'll deserialize it later. I've run the attached sdc file for various pin configurations. If I place clkctrl blocks after my bitclock, my timing is worse and fails in some data pairs. (Q1 : Why is this so? Isn't periphery clock supposed to be cooler for this?) Without placing a clkctrl block in front of the bitclk. If I put the bit clock in the middle of the input pins i.e. {datapair on pins [8..5], bitclk on pin 4, datapair on pins [3..0]} I get slightly better slack overall. If I place the bit clock on one end of the data pairs i.e. {datapair on pins [8..1], bitclk on pin 0} I get varying slacks decreasing as we move away from bitclk. Is there a rule of thumb I'm missing as to where to ideally place the bitclk? Also, how about frame clocks as well. Middle of the data pairs or on one side? I know PLL routing is ideal, but I live in the real world without PLLs on convenient input pins :-P And how is clock routing better without a periphery clock control block? Thanks ZubairLK1 Reply
p.s. I just realized that it might help placing clkctrl blocks. But connecting the DDIO megafunction before the clkctrl block directly to the pin.
And using the clock output of the clkctrl block might clock the serdes better later on. Just a hunch. Haven't checked. If you know better, feel free to comment..
