16 years agoDCLK and DATA0 connected to LVDS output instead of floating
The Cyclone II handbook says that after programming, the DCLK and DATA0 inputs should not be left floating and should therefore be connected to a logic high or low. However, it also states that th...
16 years agoThere is a valid reason why some components are called 'interface circuits' and others just 'logic'. Going over a cable definitely is an 'interface' job.
You could add a small MAXII to decode configuration messages giving you remote configuration back.
