16 years agoDCFIFO - incorrect functionality of a ModelSim timing simulation
Hey guys, A brief background:My VHDL design (for Stratix III) has input data arriving at 20MHz. The data is read at a rate of 100Mhz. The reading and writing operations aren't necessarily simul...
16 years agoI tried your project on my system (Quartus 9.0 SP2 and Modelsim 6.4a) and didn't have the same results.
First Quartus couldn't meet the timing requirements. I don't know what are your actual I/O timings, but I tweaked a bit the sdc file to make the job easier for Quartus. I didn't try to enable any optimizations or set fast paths/registers. I changed the .sdc file to this:create_clock -period 10.000 -name read_clk
create_clock -period 50.000 -name write_clk
derive_clock_uncertainty
set_input_delay -clock { read_clk } -max 2.0
set_input_delay -clock { read_clk } -min 0.0
set_input_delay -clock { write_clk } -max 2.0
set_input_delay -clock { write_clk } -min 0.0
set_input_delay -clock { write_clk } -max 3.0
set_input_delay -clock { write_clk } -min 1.0
set_output_delay -clock { read_clk } -max 0.4
set_output_delay -clock { read_clk } -min -2.0
set_output_delay -clock { write_clk } -max 0.4
set_output_delay -clock { write_clk } -min -2.0 But of course you should set requirements that are compatible with what you connect to the FPGA. Then to run the timing analysis in Modelsim I added some lines to your script: vlib lib
vmap work lib
vcom -O0 project/simulation/modelsim/DCFIFO_inst_4l_900mv_100c_slow.vho
vcom -O0 VHDL/DCFIFO_inst_tb_rtl.vhd
vsim -novopt -L altera_mf -t ps +transport_int_delays +transport_path_delays -sdfmax /DCFIFO_inst_tb/eut_DCFIFO_inst=project/simulation/modelsim/DCFIFO_inst_4l_900mv_100c_vhd_slow.sdo DCFIFO_inst_tb
add wave -color green sim:/DCFIFO_inst_tb/rst
add wave -color orange sim:/DCFIFO_inst_tb/read_clk
add wave -color orange -unsigned sim:/DCFIFO_inst_tb/read_data
add wave -color orange sim:/DCFIFO_inst_tb/read_enable
add wave -color orange sim:/DCFIFO_inst_tb/FIFO_empty
add wave -color magenta sim:/DCFIFO_inst_tb/write_clk
add wave -color magenta -unsigned sim:/DCFIFO_inst_tb/write_data
add wave -color magenta sim:/DCFIFO_inst_tb/write_enable
add wave -color magenta sim:/DCFIFO_inst_tb/FIFO_full
add wave -color yellow sim:/DCFIFO_inst_tb/good_result
add wave -color pink sim:/DCFIFO_inst_tb/done
run -all
wave zoomfull
where 'project' is the path to the Quartus project. When I ran the simulation I had timing violations at the beginning. Changing the test bench so that the clocks start at 0 instead of 1 fixed it. I'm not used to perform timing simulations so I don't know if this is normal or not. Nevertheless, the simulation ran fine. So I don't know if your problem comes from a different setting somewhere, or a bug in Quartus 10.0
