Data request from Flex (Regarding the MPN request)
Good day!!!
This is Nivas from Flextronics Component Engineering Team.
Hope you, your family and team are safe in these crazy times. Stay Safe. Let’s pray
We need some details For the below mentioned part number. Please provide the details as soon as possible because it is an urgent data request from our site.
END CUSTOMER : CISCO
END LOCATION : GUADALAJARA (Mexico)
ITEM_NUMBER |
391-CIS-16-101058-01 |
MANUFACTURER_PART_NUMBER |
5CSTFD5D5F31I7N |
MPN DESCRIPTION |
IC-FPGA,5CSTFD5-7.0,FBGA,896 P,1.0 mm,28nm,1.1 VCORE,YES-JTAG,925.0 MHz,-40 to 100 C |
GIVEN MPN IS CORRECT/INCORRECT/INVALID |
ORDERABLE MPN |
STATUS (ACTIVE OR OBSOLETE OR NRND) |
IF NRND, PLEASE PROVIDE LTB & LTS DATE |
IF OBSOLETE SUGGEST EXACT ALTERNATE MPN(IF APPLICABLE) |
MOISTURE SENSITIVITY LEVEL(IF APPLICABLE) |
SMT OR THROUGH HOLE(THT) |
PACKING_TYPE (TAPE & REEL,TRAY,TUBE OR BULK) |
ORDERABLE MPN WITH T&R PACKING OPTION(IF AVAILABLE IN T&R PACKING OPTION) |
CASE SIZE* or PACKAGE |
PART MARKING(TOP SIDE MARKING) |
ROHS STATUS (5/6 WITH EXEMPTIONS OR 6/6 WITHOUT ANY EXEMPTIONS) |
DATASHEET LINK |
IF NO DATASHEET, PLEASE CONFIRM GIVEN DESCRIPTION EXACTLY MATCHES WITH THE MPN?(YES/NO) |
1 Reply
- NurAiman_M_Intel
Please see my answer below:
GIVEN MPN IS CORRECT/INCORRECT/INVALID : CORRECT
ORDERABLE MPN:
STATUS (ACTIVE OR OBSOLETE OR NRND): ACTIVE
IF NRND, PLEASE PROVIDE LTB & LTS DATE: -
IF OBSOLETE SUGGEST EXACT ALTERNATE MPN(IF APPLICABLE):-
MOISTURE SENSITIVITY LEVEL(IF APPLICABLE): 3
SMT OR THROUGH HOLE(THT): SMT
PACKING_TYPE (TAPE & REEL,TRAY,TUBE OR BULK): TRAY
ORDERABLE MPN WITH T&R PACKING OPTION(IF AVAILABLE IN T&R PACKING OPTION): -
CASE SIZE* or PACKAGE: Tray size 31 x 31 mm
PART MARKING(TOP SIDE MARKING): -
ROHS STATUS (5/6 WITH EXEMPTIONS OR 6/6 WITHOUT ANY EXEMPTIONS): ROHS COMPLIANT
DATASHEET LINK: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_51002.pdf
IF NO DATASHEET, PLEASE CONFIRM GIVEN DESCRIPTION EXACTLY MATCHES WITH THE MPN?(YES/NO): -
Aiman
