15 years agoData Conversion card Newbie... (HSMC)
Good day. I am using the Stratix III development board. I have a Altera Data Conversion Card (HSMC) that I want to use to test ADC/DAC functionality. I don't really know where to ...
14 years ago --- Quote Start --- Do you have any documentation on any library written for accessing ADC/DAC channels? --- Quote End --- There is no 'accessing' of ADC/DAC channels. You create data streams (samples) to send to DACs and you receive samples from ADCs. You create Avalon-ST (streaming) components to feed samples to DACs, and you can treat an ADC data stream as an Avalon-ST source (that has no backpressure). The only thing a NIOS II processor can do when dealing with high-speed (high-data rate) devices like DACs (or ADCs), is setup packets in memory that are then consumed (or produced) by the Avalon-ST streams that ultimately connect to the ADCs/DACs. Before trying to create a wireless communication link in an FPGA, you first need to understand how to create one in a tool like MATLAB. Then you will have a better understanding of data (samples) flow. Cheers, Dave
