11 years agodata acquisition
Hi, I have been trying to develop a control system with DE2-115. I have to plot the values of the state variables and the output of the system, the reference signal, the control signal for each...
11 years agoI cannot understand your problem. You can simply write a VHDL/Verilog code to trigger appropriate signals. Use SignalTap and set trigger option on that specific signal. You can easily see outcomes of your design using SignalTap with speeds much higher than 1 ms, normally in the range of several nano seconds.
