9 years agoD flip flop trouble
Hello... I've written a simple VERILOG flip flop code set that isn't working in hardware. I have a debounced switch input called SW3_2. Upon the POSEDGE the output SW3_2_PRESS should toggle ...
9 years agoThe sim may have worked fine since you initialized the registers to 1. Registers initialize to 0 in hardware.
A circuit like this should really be clocked. Here's one I like that I've been using that uses a counter. button_qual high indicates a debounced button press: module button_debounce( input wire clock, input wire button, output reg button_qual = 1'b0 ); reg [19:0] button_count = 20'h00000; reg [2:0] button_reg = 3'b000; reg [1:0] button_state = 2'b00; always @ (posedge clock) begin button_reg <= {button_reg[1:0],button}; case (button_state) 2'b00: begin button_qual <= 1'b0; button_count <= 8'h00; if (button_reg[2]) button_state <= 2'b01; else button_state <= 2'b00; end 2'b01: begin button_qual <= 1'b1; button_count <= button_count + 1'b1; button_state <= 2'b10; end 2'b10: begin button_qual <= 1'b1; button_count <= button_count + 1'b1; button_state <= button_count[4] ? 2'b11 : 2'b10; end 2'b11: begin button_qual <= 1'b0; button_count <= button_count + 1'b1; button_state <= button_count[19] ? 2'b00 : 2'b11; end endcase end endmodule
