11 years agocygwin error in windows 8.1 during making hex file in nios command shell for qts 14.0
Hi all,
My OS:windows 8.1 Quartus version is :14.0 I am planning to generate hex file using nios command shell(converting elf and sof files to flash and then flash to hex) while i am running the bellow script sof2flash --epcs --input=HW.sof --output=hw.flash --quiet elf2flash --epcs --after=hw.flash --input=SW.elf --output=sw.flash cp hw.flash hw_sw.flash cat sw.flash >> hw_sw.flash nios2-elf-objcopy --input-target srec --output-target ihex hw_sw.flash My_Pjt.hex command prompt showing this issue. /********************************************************************************************************/ 2 [main] uname 3172 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to the public mailing list [email protected] 3 [main] uname 4472 find_fast_cwd: WARNING: Couldn't compute FAST_CWD pointer. Please report this problem to the public mailing list [email protected] /********************************************************************************************************/ Due to this my pof is not loading into EPCS please suggest.2 Replies
Download the patch at the bottom of this page:
http://www.altera.com/education/univ/unv-index.html Now, ignore the instructions on that page, they don't apply to 14.0 First copy C:\altera\14.0\quartus\bin64\cygwin To C:\altera\14.0\quartus\bin64\cygwin.old (To make a backup copy in case something goes wrong) Extract the files from cygwin_patch.zip to somewhere like your desktop or downloads folder, then copy the contents of the 'bin' folder (NOT the bin64 folder!) to: C:\altera\14.0\quartus\bin64 Merging folders and replacing any files. The error should have gone away. - Altera_Forum
New link - Instructions at bottom of page.
http://help.ece.ubc.ca/altera
