9 years agoCycloneIV VCCD_PLL Decoupling
Hi, what is the appropriate ground connection for the VCCD_PLL pins? None of these have GND pins nearby in the E22 package, but the name suggests that this is a digital pin, so it is refer...
9 years agoI've set up the bypass caps for VCCINT and VCCIO like
https://www.alteraforum.com/forum/attachment.php?attachmentid=13326 in order to get these voltages as stable as possible. The same thing works for VCCA, but with VCCD_PLL I'm lost here: https://www.alteraforum.com/forum/attachment.php?attachmentid=13327 So far, it's attached to a via to the ground plane, but I think this could be done better. Neither the PCG nor the checklist give an indication what the return path for these pins is. Simon
