9 years agoCycloneIV VCCD_PLL Decoupling
Hi, what is the appropriate ground connection for the VCCD_PLL pins? None of these have GND pins nearby in the E22 package, but the name suggests that this is a digital pin, so it is refer...
9 years agoHi Simon -
I recommend just following the guidelines provided by Altera for Cyclone IV: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/dp/cyclone-iv/pcg-01008.pdf https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an592.pdf Unless specifically advised otherwise by an IC vendor (even then take it with a grain of salt) your best bet is always to drop a via to a solid ground plane vs routing a trace to a ground pin. And do not split the ground plane for Cyclone IV. Hope that helps. Bob
