15 years ago
cyclone4 memory controller
Hi I am trying to build a memory controller to interface two MT47H32M16BN DDR2 devices to a Cyclone4 GX30 FGG484 FPGA.
I have got the project to compile successfully but when I run the fitter I get error messages:
Error: Cannot place pin mem_dq[14] to location W6
Error: Can't place VREF pin V9 (VREFGROUP_B3_N2) for pin mem_dq[14] of type bi-directional with 1.8-V HSTL
Class I I/O standard at location W6
Error: Too many output and bidirectional pins per VCCIO and ground pair in I/O bank 3 when the VREF pin V9
(VREFGROUP_B3_N2) is used on device EP4CGX30CF23C8 -- no more than 9 output/bidirectional pins within
12 consecutive pads are allowed when the voltage reference pins are driving in, but there are potentially
10 pins driving out
Also on the pin planner i can see 6 of my pins with errors which say "No more than 20 outputs are allowed in a VRefgroup
when Vref is being read from".
Do these messages mean that I cannot interface these two memory devices to this FPGA or should I try moving some of the
IOs onto different pins?
    Thankyou very much for this answer. I have not yet found out how to turn the 'output enable group' option ON. I have tried modifying the script file (by just changing the output_enable_group number in the pin assignments script file, but this made no difference. I guess I have to switch on the option as well as changing the group numbers, but I have no idea how to do that. Is there an example script file I can look at or is there a way of switching this option on in the GUI somewhere?
    Use different output enable groups. Set DQ,DQS,ADDR pins to output enable group "1" or any different value... E.g. "123456" is also OK.
