19 years agoCyclone3 external clamp diodes
I am getting the following warning and I have no idea why. Do I really need external clamp diodeas? Warning: Following 17 pins must use external clamping diodes. Info: Pin data[0] uses ...
19 years ago --- Quote Start --- There might be pins that don't have an internal diode available and so always require an external diode for these I/O standards. --- Quote End --- For some device families, internal PCI clamping diodes are available on only certain pins. For example, Stratix II has them only on column I/O pins. For Cyclone III, however, the device handbook on the page 7-14 I mentioned says, "Cyclone III devices provide an optional PCI-clamp diode enabled input and output for each I/O pin" (emphasis added). Even though the internal diode is available on all Cyclone III I/O pins, you might not be able to use it. I have had to turn it off on dual-purpose pins being used for both user I/O and Active Serial configuration if I placed an input-only or bidirectional signal on those pins. Turning off the PCI clamping diode results in the warning in the original post for I/O standards that require inputs to be clamped.
