Legos07
9 months agoCyclone10LP Remote System Upgrade
Hi guys, I am working on implementing Remote System Upgrade for my Cyclone 10LP FPGA, which loads its configuration data from an external flash device (MT25QL128). I've reviewed multiple documents o...
Magic
1 hour agoHi Legos07,
I've built the design for the Cyclone 10 LP, which includes both RSU and GSFI.
I also successfully accessed the MT25QL128 using this design.
I believe GSFI suppot smaller capacity then 256Mb.
If you configure GSFI for 3-byte addressing mode, which supports 128Mb off course.
Also you can make your custom flash spec file as you like and create jic file using it even not listed originally.
Convert Programming Files -> Configuration Device -> <<new device>>
BR,
Magic
