Legos07
8 months agoCyclone10LP Remote System Upgrade
Hi guys, I am working on implementing Remote System Upgrade for my Cyclone 10LP FPGA, which loads its configuration data from an external flash device (MT25QL128). I've reviewed multiple documents o...
FakhrulA_altera
7 months agoHi Legos07,
Quick actions:
1)Use ASMI Parallel II or GSFI IP for flash access. The configuration SPI pins are dedicated, not driven by user logic. [cdrdv2-pub....intel.com], [macnica.co.jp]
2)Enable MT25Q support in Quartus via quartus.ini:
INIpgm_allow_mt25q=onShow more lines
Regenerate IP and programming files.
3) If MT25QL128 is not listed in Remote Update IP, pick a Macronix part with the same density and keep “Enable reconfig POF checking” unchecked.
4) Build a JIC with fixed start addresses, then write the boot address and trigger reconfig. Use the watchdog only if your app services it
Fakhrul
