EZacc
8 years agoCyclone V XCVR configuration for SATA I application.
Dear Sir, I'm trying to configure the Cyclone V transceiver in order to establish a SATA I connection. Unfortunately, I don't know if my actual configuration is the right one. The problem is the ...
EZacc
8 years agoHi,
Unfortunately, I can't change the QSF assignment, because if I change it, my OOB sequence does not finish.
Now the question is: Should I assume that in each cycle in which the signal detect is low the PHY output data are corrupted?
Thank you.
