8 years agoCyclone V won't configure via active serial
I have a Cyclone V design (5CSEBA5) that I am trying to configure using a EPCQ128 device I have created a .sof file that I can load into the FPGA directly (Jtag USB Blaster) and it works fine (...
8 years agoI have (hopefully) attached a screen shot of the Convert Programming File setup that I used. I am not seeing the attachment in the "preview" but it says it is attached so maybe it will appear.
--- Quote Start --- Try with below options Tick memory file check box while generating .jic file.(To generate output_file.map) --- Quote End --- Okay, this is what the map file says: BLOCK START ADDRESS END ADDRESS Page_0 0x00000000 0x006AEBCF Configuration device: 5CSEBA5 Configuration mode: Active Serial x4 Quad-Serial configuration device dummy clock cycle: 12 Notes: - Data checksum for this conversion is 0x99FF6008 - All the addresses in this file are byte addresses --- Quote Start --- 1.Check the pin nConfig and nStatus in reset state it should be high state. 2.Is it development board/custom board?- If it is custom board: Do you have any hardware/IC in path on nSTATUS and CONF_DONE (like line driver / TRX).
