CNiclaes
4 years agoCyclone V with or w/o E Hard Memory Controller - programming file compatibility
I've a design using this Cyclone V E device without HMC: 5CEBA9F23C7N
For sourcing reason I would like maybe to use the version with HMC : 5CEFA9F23C7N
If the design is the same, can I use the sa...
- 4 years ago
Hello CNiclaes,
"But when I change the target device from 5CEBxxx to 5CEFxxx in Quartus and compile the same design, the generated programming files are exactly the same!"
- Yes I think it's might look like a same one but the targeted device has been changed.
- To confirm this parameter, you can check your QSF file and observe the targeted device parameter.
"That's why I ask a confirmation from Intel that such a design will work on either chip?"
- Yes the design should be working fine with the targeted device.
sstrell
4 years agoNo. If you're accessing memory in different ways between two different devices (soft vs. hard controller), you'll need a separate Quartus project (or project revision) and recompile for the other device producing a different programming file. There's no way the design could be the same because there will be differences in your options for the memory controller.
