CNiclaes's avatar
CNiclaes
4 years ago
Cyclone V with or w/o E Hard Memory Controller - programming file compatibility
I've a design using this Cyclone V E device without HMC: 5CEBA9F23C7N
For sourcing reason I would like maybe to use the version with HMC : 5CEFA9F23C7N
If the design is the same, can I use the same programming file for either device?
  • Hello CNiclaes,
    "But when I change the target device from 5CEBxxx to 5CEFxxx in Quartus and compile the same design, the generated programming files are exactly the same!"
    • Yes I think it's might look like a same one but the targeted device has been changed.
    • To confirm this parameter, you can check your QSF file and observe the targeted device parameter.
    "That's why I ask a confirmation from Intel that such a design will work on either chip?"
    • Yes the design should be working fine with the targeted device.
  • AdzimZM_Altera's avatar
    AdzimZM_Altera
    We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    AdzimZM_Altera
    Hello CNiclaes,
  • CNiclaes's avatar
    CNiclaes
    I fully understand.
  • CNiclaes's avatar
    CNiclaes
    Thanks for your reply, but it seems that my question was not clear enough.
    My design doesn't use any hard or soft memory controller.
    In the meantime I tested to compile the design by just replacing the "B" device by the "F" device and the generated RBF file is exactly the same, so I suppose I can use it with either one device or the other.
    Another fact is related to the Quartus Programmer. When connecting a ByteBlaster for SOF file programming the programmer ask if it is a "B" or an "F", meaning it can't make the difference.
    But I would like to have an official confirmation from Intel I can do that before purchasing and assembling "F" version on my boards instead of "B" version.
  • sstrell's avatar
    sstrell
    No. If you're accessing memory in different ways between two different devices (soft vs. hard controller), you'll need a separate Quartus project (or project revision) and recompile for the other device producing a different programming file. There's no way the design could be the same because there will be differences in your options for the memory controller.
