12 years agoCyclone V Triple Speed Ethernet in Quartus 13.1
Hi I'm Working with the Development Kit c5efa7. I used the example board update portal and compiled it for myself in quartus 12.1 with the eclipse nios example Simple Socket Server (RGMII)...
11 years agoSimon,
Were you able to get you issue resolved? I had TSE working in quartus 13.1 (I built the system using Qsys). I havve updated to quartus 14 and now TSE no longer works. I get the following error: [altera_eth_tse_init] Error opening TX SGDMA init error -22 on net[0] Strangely enough, If I debug and step through the code, it will correctly find and initialize the TSE/PHY... but the program crashes soon after. The code that I am using hasn't changed from version 13 to version 14, I only updated the bsp. Any help would be greatly appreciated. FYI I am using the Arria V GX starter kit. --- Quote Start --- Hi, I have the same problem, my triple speed ethernet is ok with previous version of TSE + FreeRTOS and LWIP but with the update not, i have sgdma tx and rx. The sgdma RX seem to receive data, tx can send data, but there a stop in TSE (i suspect something with the PHY i use marvel rgmii 88E1111). the TSE User guide don't talk about a major update, and i can't found what's change... Can someone has already get a Triple speed ethernet since quartus 13.1 ?? maybe could we see a .qsys file and vhdl example ??? thanks Simon --- Quote End ---
