11 years agocyclone V transceiver using as IO?
Hi, For extraxting data from a 576Mbps serial datastream (subLVDS) with a DDR clock of 288MHz I would like to use the transceiver inputs of the Cyclone V. Can I do this easily? Can I use the tr...
10 years ago --- Quote Start --- I am trying to use subLVDS I/O on the SOC cyclone dev kit. I have a camera with DDR2 outputs, do I need to wire the data and clocks to the transceiver ports on the FPGA, or can I just use a macrocell configuration on any differential pins (that support sub-LVDS)? I am not getting sensible data from the camera as yet when I use bank 8A for the subLVDS data and clk inputs. --- Quote End --- Hi, I use DIFFIO_RX sub_LVDS input of bank 4A for the serial data input and CLK3P/N of the clock input of that bank also sub_LVDS (DDR). That works nicely. You have to take care of impedance matching and a good cable or other connection. To convert the serial data stream to parallel data, ALTLVDS_RX function is used. Hope this helps.
