11 years agocyclone V transceiver using as IO?
Hi, For extraxting data from a 576Mbps serial datastream (subLVDS) with a DDR clock of 288MHz I would like to use the transceiver inputs of the Cyclone V. Can I do this easily? Can I use the tr...
10 years agoI am trying to use subLVDS I/O on the SOC cyclone dev kit. I have a camera with DDR2 outputs, do I need to wire the data and clocks to the transceiver ports on the FPGA, or can I just use a macrocell configuration on any differential pins (that support sub-LVDS)? I am not getting sensible data from the camera as yet when I use bank 8A for the subLVDS data and clk inputs.
