13 years ago
Cyclone V Transceiver Synchronised 32bit Word Alignment Problem
I am using the cyclone v gt (http://www.altera.co.uk/products/devkits/altera/kit-cyclone-v-gx.html) demo board in an attempt to get a transceiver channel that has a direct loopback (Tx->Rx) across the HSMC to verify a physical link running and synchronised correctly at the receiver from the transmitted data.
The loopback is as follows:-
  • The transceiver is constantly transmitting = K28.5, D10.2, D10.2 & D27.3 (SATA align primitive in transmission order) i.e. 7b4a4abch in the 8b-domain.
  • The transceiver is receiving = 7b4a4abch which is good :) OR 4abc7b4ah which is word swapped :(
After reading the documentation many times I can't work out why the word ordering isn't working, word alignment appears to work though; this is my configuration in the receiver:-
  1. The PMA-PCS interface is configured as a 20bit data path.
  2. The word aligner is in manual mode detecting x2 comma K28.5 (10bit) symbols which appears to be working because using SignalTap I can see the synchronisation being asserted after detecting the second word alignment pattern.
  3. The rate match FIFO is bypassed.
  4. I am using the 8b/10b decoder
  5. I am using the byte (16bit word) deserialiser to get a 32bit data path to the FPGA fabric.
  6. I have the byte ordering configured to auto looking for the comma K28.5 pattern in the 8b-domain i.e. 1BCh and padding with 000h.
  7. I am using the phase compensation FIFO in the non-registered low-latency mode.
But it would seem that the byte ordering block isn't working because if I have read the documentation correctly this would detect my word swapped scenario (4abc7b4ah) which would be replaced with the padding such that the word alignment is restored back to the original data alignment. Any help is much appreciated because I think I have exhausted all my ideas from reading the documentation many times now.
