11 years agoCyclone V: switching between application images using altremote_update
Hi all, I am using a Cyclone V in a custom design and I have some issues while using the altremote_update megafunction: I have 3 different images stored in an EPCS device: factory image, ...
11 years agoThanks.
To this point, I have had similar experiences/observations with the .rbf and .rpd (bit reversal, compression on, no timing issues, no bit corruption that I can see.) In both cases, the board gets stuck in an infinite loop upon startup. The clock starts around 10MHz through initial config stages, then jumps up to about 90MHz for the quad-read. In this phase, the data is being read on 4 data lines from the flash device, but then goes back to the beginning of the boot cycle. Do you think it may have to do with some setting or checkbox when creating the file?
