11 years agoCyclone V: switching between application images using altremote_update
Hi all, I am using a Cyclone V in a custom design and I have some issues while using the altremote_update megafunction: I have 3 different images stored in an EPCS device: factory image, ...
11 years agoI'd first just try reading the image from the epcq.
This is really easy to do if you have access to actual epcq pins. You just big-bang out a read command (initially test with address 0) and then bit-band in the read data. For cyclone V (Arria II and later) the epcq is configured for two extra dummy clocks so that they can use epcq256 with 4 byte addresses. You can read the nv status register to find this out - but for a specific board you know what is there.
