11 years agoCyclone V: switching between application images using altremote_update
Hi all, I am using a Cyclone V in a custom design and I have some issues while using the altremote_update megafunction: I have 3 different images stored in an EPCS device: factory image, ...
11 years ago --- Quote Start --- Hi julianca, You need to use a .rbf file or a .rpd file, depending on the kind of FPGA you are using (you can create .rbf and .rpd files via the same tool, via Convert Programming Files). QUOTE] Yes thank you, this is exactly what I was asking. I am currently paused my project, loaded the .jic via JTAG, and I am using a logic analyzer to view what is being read out of the EPROM... it goes through a process that includes Read Status, Read Device ID, etc, and I'm afraid that my application will have to mimic these steps. I may first try to write the .rbf file to the EPROM, and load upon power cycle/boot up without adding those extra steps. (The final goal is to include reboot selected images. Baby steps.)
