Altera_Customer's avatar
Altera_Customer
6 years ago
[Cyclone V SoC] Trouble implementing FPGA-to-HPS Bridges Design Example (Intel Design Example)
Hello all,
First of all, I am a novice when it comes to soc development. I was trying to implement Intel's FPGA-to-HPS Bridges Design Example (https://www.intel.com/content/www/us/en/programmable/support/support-resources/design-examples/soc/fpga-to-hps-bridges-design-example.html?elq_cid=6249859&erpm_id=9362042) on my DE1-SoC board.
I edited the quartus files to reflect the SDRAM timings of this board, ran tcl scripts and updated the main verilog file to reflect the pin assignments, and then I compiled correctly and uploaded to the board.
Then, following the design example instructions, I imported the project into eclipse, built successfully, and then ran the program in DS-5 Debugger mode. The program ran but stalled at a wait point in the debug file. Here is a snip of what appears in the command window:
Connected to running target Altera - Cyclone V SoC (Dual Core)
cd "C:\[...]\CV_FPGA_to_HPS_Bridge_Design_Example\software\Altera-SoCFPGA-HardwareLib-FPGA2HPS-Bridge-CV-GNU"
Working directory "C:\[...]\CV_FPGA_to_HPS_Bridge_Design_Example\software\Altera-SoCFPGA-HardwareLib-FPGA2HPS-Bridge-CV-GNU"
source /v "C:\Program Files\DS-5 v5.29.3\sw\debugger\configdb\Scripts\altera_target_check.py"
No SYSID registers could be found. Has a peripheral description file been supplied?
source /v "C:\[...]\CV_FPGA_to_HPS_Bridge_Design_Example\software\Altera-SoCFPGA-HardwareLib-FPGA2HPS-Bridge-CV-GNU\debug-hosted.ds"
+reset system
+wait 30s
Target has been reset
Execution stopped in SVC mode due to a breakpoint or watchpoint: S:0x00000000
S:0x00000000   LDR      pc,[pc,#24] ; [0x20] = 0xA8
+stop
WARNING(CMD315): Target is not running
+wait 30s
+set semihosting enabled false
+loadfile "$sdir/u-boot-spl.axf" 0x0
Loaded section .text: S:0xFFFF0000 ~ S:0xFFFF6FE3 (size 0x6FE4)
Loaded section .rodata: S:0xFFFF6FE4 ~ S:0xFFFF8E1F (size 0x1E3C)
Loaded section .data: S:0xFFFF8E20 ~ S:0xFFFF9CF3 (size 0xED4)
Entry point S:0xFFFF0000
+set semihosting enabled true
Semihosting server socket created at port 8000
+delete
All user breakpoints deleted
+tbreak spl_boot_device
Breakpoint 1 at S:0xFFFF1478
+run
Starting target with image C:\[...]\CV_FPGA_to_HPS_Bridge_Design_Example\software\Altera-SoCFPGA-HardwareLib-FPGA2HPS-Bridge-CV-GNU\u-boot-spl.axf
Running from entry point
+wait
Why does the program just stop here? It is as if it does not find the breakpoint? Pressing the continue button does not do anything in Eclipse. I do not know how to address this problem, and I didn't change a lot from the design example, so I feel like it should work well unless I'm running it incorrectly.
Any help at all would be greatly appreciated! If I can get this example to work it would be so useful to me
