Cyclone V SoC interrupt IDs
- 4 years ago
Yes, thank you Aik Eu and Tru, I see the info now.
It turns out that my problem was an incomplete pdf version of the manual. The pdf manual that you get when you press the download button on the on-line manual page includes this information as chapter 10. The manual I've been working from has the same name (cv_5v4) and same date (2021.07.08) but doesn't include this chapter. On the manual I've been using chapter 10 is the CoreSight debug chapter which is chapter 11 in the newer manual.
Very strange, I thought I had gotten my pdf through the same download link a few weeks ago but perhaps I found it elsewhere.
Anyway, I have the info I need now so thank you both very much!
- Steve
Hi SGlow,
If it is related to the device tree interrupt value:
Example:
For HPS UART0 it is 162
For HPS UART1 it is 163
Referring to the GIC Interrupt map:
For HPS UART0 it is 194, so minus 32 will be 162
For HPS UART1 it is 195, so minus 32 will be 163
You may use the below two documents for your reference:
https://developer.arm.com/documentation/ihi0048/latest/
http://ecse324.ece.mcgill.ca/_downloads/eb3bd46aeaebdd7c592e61dbc13dc1d3/Using_GIC.pdf
Aik Eu
