Cyclone V SOC design upgrade from Quartus 18.1 to 20.1
- 5 years ago
I think this has something to do with your file path. Because now that your project is compiled on a shared drive, Quartus cannot find the "sld_hub_pack" file since your Quartus software is installed to your PC.
You should map a network drive to the shared drive. This way the shared drive is mapped on your PC drive and Quartus is now able to find the file.
Here are steps for you to do so: https://support.microsoft.com/en-us/windows/map-a-network-drive-in-windows-10-29ce55d1-34e3-a7e2-4801-131475f9557d
Nurina
The Quartus tool is installed on the PC's local drive. The project is not. It needed to be on a drive that is accessible from other PCs.
The full error log:
Warning (12019): Can't analyze file -- file //albmain/share/EngLab/StofferM/SBR_1_v18p1_good_compile_restored_in_v20p1/sld_hub.vhd is missing
Info (12021): Found 1 design units, including 1 entities, in source file db/ip/sld51cb7f85/alt_sld_fab.v
Info (12023): Found entity 1: alt_sld_fab
Info (12021): Found 1 design units, including 1 entities, in source file db/ip/sld51cb7f85/submodules/alt_sld_fab_alt_sld_fab.v
Info (12023): Found entity 1: alt_sld_fab_alt_sld_fab
Info (12021): Found 1 design units, including 1 entities, in source file db/ip/sld51cb7f85/submodules/alt_sld_fab_alt_sld_fab_ident.sv
Info (12023): Found entity 1: alt_sld_fab_alt_sld_fab_ident
Info (12021): Found 1 design units, including 1 entities, in source file db/ip/sld51cb7f85/submodules/alt_sld_fab_alt_sld_fab_presplit.sv
Info (12023): Found entity 1: alt_sld_fab_alt_sld_fab_presplit
Info (12021): Found 2 design units, including 1 entities, in source file db/ip/sld51cb7f85/submodules/alt_sld_fab_alt_sld_fab_sldfabric.vhd
Info (12022): Found design unit 1: alt_sld_fab_alt_sld_fab_sldfabric-rtl
Info (12023): Found entity 1: alt_sld_fab_alt_sld_fab_sldfabric
Info (12021): Found 1 design units, including 1 entities, in source file db/ip/sld51cb7f85/submodules/alt_sld_fab_alt_sld_fab_splitter.sv
Info (12023): Found entity 1: alt_sld_fab_alt_sld_fab_splitter
Error (10481): VHDL Use Clause error at alt_sld_fab_alt_sld_fab_sldfabric.vhd(7): design library "altera_sld" does not contain primary unit "sld_hub_pack". Verify that the primary unit exists in the library and has been successfully compiled.
Error (10800): VHDL error at alt_sld_fab_alt_sld_fab_sldfabric.vhd(7): selected name in use clause is not an expanded name
Error (10481): VHDL Use Clause error at alt_sld_fab_alt_sld_fab_sldfabric.vhd(8): design library "altera_sld" does not contain primary unit "sld_jtag_hub_pack". Verify that the primary unit exists in the library and has been successfully compiled.
Error (10800): VHDL error at alt_sld_fab_alt_sld_fab_sldfabric.vhd(8): selected name in use clause is not an expanded name
Error (10481): VHDL Use Clause error at alt_sld_fab_alt_sld_fab_sldfabric.vhd(9): design library "altera_sld" does not contain primary unit "jtag_pack". Verify that the primary unit exists in the library and has been successfully compiled.
Error (10800): VHDL error at alt_sld_fab_alt_sld_fab_sldfabric.vhd(9): selected name in use clause is not an expanded name
Warning (12241): 40 hierarchies have connectivity warnings - see the Connectivity Checks report folder
Info (144001): Generated suppressed messages file //albmain/share/EngLab/StofferM/SBR_1_v18p1_good_compile_restored_in_v20p1/output_files/SBR_1.map.smsg
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 6 errors, 99 warnings
Error: Peak virtual memory: 5301 megabytes
Error: Processing ended: Thu May 20 10:45:46 2021
Error: Elapsed time: 00:05:49
Error: Total CPU time (on all processors): 00:05:09
Also see warnings like one shown below, which has never been the case on any other project (I wonder if the Quartus install was done correctly since I can't do it - has to be done by our IT department):
Warning (12125): Using design file db/altsyncram_7nn1.tdf, which is not specified as a design file for the current project, but contains definitions for 1 design units and 1 entities in project
Info (12023): Found entity 1: altsyncram_7nn1
- MStof15 years ago
I tried copying the project to the local C: drive of the PC being used. Now the project compiles!
This is something that changed from version 18.1 to 20.1! I was using the project in the same folder with version 18.1 with no problems.
This is a problem, since others need access to this project.
