Cyclone V SoC 5CSXC6 Series GXB Utilization and Limitations
- 2 months ago
Hi Brian,
Thank you for the update.
Just to clarify, the legacy database I referred to is our internal database for legacy devices. Unfortunately, there is limited information available regarding this wrong data issue. Based on the available info, I believe it was originally initiated from a customer-reported case.
You are also correct that the placement rules are enforced within Quartus. Since these rules are built into the tool, they cannot be overridden through a TCL command.
I apologize for any inconvenience this may cause.
OK.
For wrong data, you kept referring to legacy database, this is from internal FAE / staffs only?
Do wrong data reports from customers or internal smoke / sanity tests?
There is no way we can use with newer version no override no tcl command to bypass fitter rules on coexist?
Brian
Hi Brian,
- BrianSune_Froum2 months ago
Contributor
I guess we had this more than enough on understanding the whold story.
I deeply appreciate the sharing and assisting on this ticket.
I will close and report as solution.
So I think 17.x is still worth to keep.
Thanks,Brian
