AJienNew Contributor7 years agoCyclone V SE Signaltap pin placement Hi all, I've been trying to add a Signal Tap instance to my design on a Cyclone V SE (5CSEMA4U23C6) using Quartus Prime 18.0/18.1. I setup the Signal Tap using Tools -> Signal Tap Logic Analyzer an...Show More
sstrellSuper Contributor7 years agoThose are the JTAG pins. Are you using any other IP or anything that makes use of JTAG?
AJienNew Contributor to sstrell7 years agoNo, the only JTAG related function I'm using is Signal Tap.
Recent DiscussionsVcm for the clock input pins of agilex5 E-series FPGA A5ED065BB32AE5SR0Arria 10: Remote Update Factory Fallback won't work & Watchdog does not triggerIBIS models GTS banks agilex 5EClarification on Arria 10 Design Security Featuresrsu_client failing to write to slot
