AJien
7 years agoCyclone V SE Signaltap pin placement
Hi all, I've been trying to add a Signal Tap instance to my design on a Cyclone V SE (5CSEMA4U23C6) using Quartus Prime 18.0/18.1. I setup the Signal Tap using Tools -> Signal Tap Logic Analyzer an...
Rahul_S_Intel1
7 years agoHi ,
From the error description what i found that you are been using the reserved pin for your usage. I am suggesting the below .
1. Include the signal tap
2.Put the pin assignment on auto
See the design is working , if the above is working we can assume signal tap is not the reason for the error.
AJien
7 years agoHi,
The steps listed were exactly what I did. The pin assignments were picked by Quartus Prime (Lite edition, 18.0/18.1) automatically. All I did was include the Signal Tap and I did not set the pin assignments myself.
