Cyclone V QSPI AS Configuration timing data
- 4 years ago
Hi Sudheer,
You can use the 1.5nS. That will also protect you if you need to change to EPCQ-A device in the future because the EPCQ device is EOL (https://www.mouser.com/pcn/intel_corporation_pdn1708_rev_1.0.0.pdf).
There is not much functional difference between the two. I think Intel's supplier for EPCQ shut down so they had to create a new part and called it EPCQ-A.
Travis
Hi Travis,
Looks like the snapshot you have provided is for the EPCQ64A devices with 1.5nS output hold time. We are using EPCQ64SI16N without 'A' suffix.
Can we use 1.5nS output hold time for EPCQ64SI16N as well?
Can you please elaborate what is the difference between EPCQ64A and EPCQ64 devices?
Sudheer
Hi Sudheer,
Travis
- SudheerV4 years ago
Thanks Travis for the information.
This concludes our discussion.
