Cyclone V QSPI AS Configuration timing data
- 4 years ago
Hi Sudheer,
You can use the 1.5nS. That will also protect you if you need to change to EPCQ-A device in the future because the EPCQ device is EOL (https://www.mouser.com/pcn/intel_corporation_pdn1708_rev_1.0.0.pdf).
There is not much functional difference between the two. I think Intel's supplier for EPCQ shut down so they had to create a new part and called it EPCQ-A.
Travis
Hi Sudheer,
Please refer to the Device Handbook in the section on Evaluating Data Setup and Hold Timing.
Cyclone V Device Timing: https://www.intel.com/content/www/us/en/docs/programmable/683801/current/active-serial-as-configuration-timing.html
Here is a migration guide that can also help. https://www.intel.com/content/www/us/en/docs/programmable/683340/current/fpga-configuration-device-migration.html
Be careful when calculating the hold time. You might need to add a 10pF capacitor on the data lines if you cannot meet the hold time in the calculation.
If you look at the timing waveforms, the data is captured on the falling edge.
Travis Covert
