Cyclone V PLL Normal compensation not working as it should
Any takers for this question?
I am using a PLL with normal compensation. From my understanding this compensation should account for the clock routing delay from the PLL to the registers, making the skew between the PLL input clock and the clock arriving at the register almost 0. What I see when I implement the design is that I have a skew of several nanoseconds, no matter what I do. This becomes specially bad when I try to drive the IO registers and meet timing.
As an example, my design (Cyclone V SoC) uses a 125 MHz clock which is used to clock some FPGA logic and the an external device. There is a SDR bus between the FPGA and the external device running at that frequnecy. The clock (single ended) is placed on a positive clock pad. I'm trying to meet IO setup/hold with this clock, but it can't be done with a direct connection (tried and discarded due to the long propagation delay of the clock network) so I am currently using a PLL phase shift in combination with a multicycle constraint for setup (no hold) to shift the data valid window.
The settings for the PLL are as follow: PLL, fin=fout=125 MHz, Phase shift: 144°, Normal compensation.
The location of the IOs and the reduced logic size allows me to use a regional clock network, so I force the output clock buffer of the PLL to be regional.
The output registers are are forced to be packed into the IOs to reduce as much as possible the data propagation delay.
With all these, the PLL does not seem to be working as expecting:
8.823 5.623
3.200 0.000 (source latency, due to phase shift I guess)
3.200 0.000 1 PIN_AF14
3.200 0.000 RR IC 1 IOIBUF_X32_Y0_N1
4.100 0.900 RR CELL 1 IOIBUF_X32_Y0_N1
5.421 1.321 RR IC 1 PLLREFCLKSELECT_X0_Y7_N0
5.754 0.333 RR CELL 1 PLLREFCLKSELECT_X0_Y7_N0
5.754 0.000 RR IC 10 FRACTIONALPLL_X0_Y1_N0
1.841 -3.913 RR COMP 1 FRACTIONALPLL_X0_Y1_N0
1.841 0.000 RR IC 1 PLLOUTPUTCOUNTER_X0_Y0_N1
3.369 1.528 RR CELL 2 PLLOUTPUTCOUNTER_X0_Y0_N1
4.511 1.142 RR IC 1 CLKCTRL_R31
4.771 0.260 RR CELL 1390 CLKCTRL_R31
7.899 3.128 RR IC 1 DDIOOUTCELL_X14_Y0_N44
8.823 0.924 RR CELL 1 DDIOOUTCELL_X14_Y0_N44
So I'm getting an effective clock skew of -5.6 ns. As can be seen, the PLL compensates for 3.913 ns. Anyone can explain to me if this is the intended behaviour, or what am I doing wrong?
Kind regards
