jrrguzman
8 years agoCyclone V PLL Normal compensation not working as it should
Hi, I'm trying to meet IO timing with a Cyclone V based design. The design uses a clock (135 MHz) connected to a dedicated clock PAD with direct connection to the PLLs. After setting up the PLL into...
LinuxFanatic2018
8 years agoHow you determine that "not compensating"? Modeling? Oscilloscope? Or just timing analysis report tells you that? Give more details about.
