10 years agoCYCLONE V OCT Problem
I am using in my design a Cyclone V device (namely the 5CGXBC3B7U15C8N), while using PIN#M13, N12 as an LVDS RX port. Going through ALTERA device handbook, it has two variations for On Chip Termination: - Embedded inside FPGA. - On board termination. Does declaring LVDS inside QUARTUSII automatically attributes a 100ohm OCT for this pair? Thank you for your answers, Refael.3 Replies
You can adjust the On-Chip Termination (OCT) via this same 'Input Termination' parameter - various OCT options are available. However, I'm sure not all (if any) of the the OCT options will be valid for LVDS. I suspect you'll only be able to switch it OFF or leave it a it's default. Play around with it to see.
--- Quote Start --- what is the termination value if this resistor is missing? --- Quote End --- Something that's not correct. The handbook doesn't cover this eventuality. Unfortunately, if you've not followed the guidelines, you're on your own. However, --- Quote Start --- Some specific DQ pins can also be used as RZQ pins. If you need extra RZQ pins, you can use these [the] DQ pins as RZQ pins instead. --- Quote End --- So, depending on your board you may be able to salvage something by using an alternative pin. Cheers, Alex - Altera_Forum
Hi Alex,
Thank you for your reply. So, I receive differential termination by default, can I alter this value to a new value of my choosing? Also, currently in my design the RZQ resistor is not connected. From Altera's handbook I can see this resistor is used for calibration purposes, what is the termination value if this resistor is missing? Thanks, Refael. - Altera_Forum
--- Quote Start --- The Cyclone V devices provide a 100 Ω, on-chip differential termination option on each differential receiver channel for LVDS standards. On-chip termination saves board space by eliminating the need to add external resistors on the board. You can enable on-chip termination in the Quartus Prime software Assignment Editor. --- Quote End --- By selecting LVDS you will automatically get the termination resistor. However, you can remove this by setting the 'Input Termination' to 'Off', or adding a line to the project's Quartus Settings File (.qsf): --- Quote Start --- set_instance_assignment -name INPUT_TERMINATION OFF -to your_input_signal --- Quote End --- Cheers, Alex
