12 years agoCyclone V LVDS_Rx input clk
hi, I am working with Cyclone V to receive high rate data from ADC,the clock from ADC is 500MHz, but the LVDS_rx input clock(f hsclkin on datasheet)can only be 437.5MHz.and then, When i ...
12 years agoHello I am doing a similar design but with four ADCs and in a Cyclone 3.
However I am confused about the LVDS clock signal input: are all the input clock IO pins dedicated LVDS? I do not want to have problems about clock mismatches so I need to confirm the IO input clock pin is LVDS compatible, no emulated? I know that for transmitters the question is different but for receivers I didn't find any information. Thanks in advance. Regards
