13 years agoCyclone V LVDS & DDR3 on same bank
I am planning to use a Cyclone V 5CGTFD7D5F31 with the following requirements; - 32 bit DDR3 interface Top and Bottom (64 bit total) - 68 LVDS input pairs Once I have assigned pins to the HMC for the DDR3 interfaces I am left with the following available LVDS RX pairs per bank; 3A: 8 3B: 6 4A: 5 5A: 8 5B: 12 6A: 20 7A: 5 8A: 14 Total: 78 The HMC uses banks 3B, 4A, 7A & 8A, so I will need to have both LVDS and DDR3 signals in these same banks. Here’s the crunch: DDR3 requires that VCCIO is set to 1.5V, while LVDS requires that VCCIO is set to 2.5V. VCCPD should be 2.5V in both cases (table 5-1). From C5 handbook, Vol 2: Page 5-2; “VCCPD powers the LVDS input buffers”. Page 5-12; LVDS Input RD OCT; “You can use RD OCT when you set both the VCCIO and VCCPD to 2.5 V.” So, assuming that the LVDS input buffers are powered from VCCPD = 2.5V, can I use the LVDS differential inputs if VCCIO is set to 1.5V fro DDR3? Also, can I use RD OCT? If not, can I do it with external RD? Any guidance would be greatly appreciated! Thanks, Ken
