ZLu001
7 years agoCyclone V IO's can't work on any peripherals, even I2C memory.
same circuits and HDL for cyclone V and IV IO's. it works on cyclone IV, but can't work on Cyclone V for any peripherals, even I2C memory. I tried program the IO's for different voltage setting, but ...
a_x_h_75
Contributor
7 years agoHave you constrained your IO for your Cyclone V project? Have you check the report files? It sounds like the pins you are monitoring with your 'oscillator' (oscilloscope?) are unasigned and are probably floating.
Cheers,
Alex
