12 years agoCyclone V HSMC Lvds differential pairs direction
Hi, I am developing a board to work with the HSMC connector and will require 26 LVDS differential receive pairs. There are only 17 RX pairs and 17 TX pairs. Can the TX pairs be used as inputs so that...
12 years ago --- Quote Start --- When i went over the HSMC specs document I understood it was more general and not board specific. --- Quote End --- The HSMC specification was something created by Altera, and only Altera use it. It is *board specific* in that boards that follow the specification should be compatible. --- Quote Start --- But if its true the HSMC LVDS TX differential lanes can be redefined so that i can use all 34 differential pairs as RX, then that will be perfect. --- Quote End --- They cannot be re-defined if you want to call your board HSMC compliant. The specification *states* their direction. You could create a board that does not adhere to the specification, but then you would not call it an HSMC board :) Bottom line is that you can use the Samtec HSMC connector however you see fit, but if you want to interface to other HSMC boards, then you must stick to the specification. Cheers, Dave
