roelof
5 years agoCyclone V HPS Baremetal Watchdog Error
I Am trying to get the Watchdog to generate a warm reset on my HPS Baremetal Application.
My Setup:
Cyclone V custom board
Boot setup; BootRom -> Preloader -> HPS baremetal
Preloader and HPS ...
- 5 years ago
May I know the Quartus version that you are using?
How did you compile the preloader? Is it using the bsp-editor?
Regarding the reset issue, could you check below documentation since you are using Cyclone V SoC and QSPI to boot if the issue that you are seeing related, and that you may try the solutions mentioned:
https://rocketboards.org/foswiki/Documentation/SocBoardQspiBoot
roelof
5 years agoGood day EBERLAZARE_I_In
Thank you for your quick response. I went through the document you provided and was able to resolve my issue. The QSPI needs to be reset before the watchdog triggers - else the HPS cannot boot.
Thank you
EBERLAZARE_I_Intel
5 years agoHelo,
Glad I could help!
