Cyclone V HPS Baremetal Watchdog Error
- 5 years ago
May I know the Quartus version that you are using?
How did you compile the preloader? Is it using the bsp-editor?
Regarding the reset issue, could you check below documentation since you are using Cyclone V SoC and QSPI to boot if the issue that you are seeing related, and that you may try the solutions mentioned:
https://rocketboards.org/foswiki/Documentation/SocBoardQspiBoot
Good day EBERLAZARE_I_In
Thank you for your quick response. I went through the document you provided and was able to resolve my issue. The QSPI needs to be reset before the watchdog triggers - else the HPS cannot boot.
Thank you
- EBERLAZARE_I_Intel5 years ago
Helo,
Glad I could help!
